CAM for my sprayed ZZ4? Help
Old Feb 4, 2002 | 03:03 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Any sugestions are greatly appreciated. Check my sig for my mods. My best time now is 13.54 @ 102.87mph. Thats on motor, I would eventually like to run mid to low 12's on motor and spray 11's. I do drive this car everyday but I don't mind a rough Idle. Thanks for all the help in advance.
Old Feb 4, 2002 | 09:09 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
of the two choices i see, for crane i'd pick : HR-276-2S-12-IG and for comp cams i'd pick: 08-503-8. these two would be your most readily available.
Old Feb 5, 2002 | 09:39 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Did you ever run the car with the intake that came on the ZZ4? (I am assuming you bought the ZZ4 as a crate engine). I have thought of that combo, ZZ4 and TPI, but I would think that engine would breathe more air than a TPI base could flow.
Old Feb 7, 2002 | 03:58 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Never ran it w/ a carb. I will be going w/ a LT1 intake soon. I gained 13 lbs of tq but lost almost 50 hp.
Old Feb 7, 2002 | 06:17 PM
espirocz's Avatar
You might just want to throw a set of 1.6 full roller rockers on your ZZ4. Just make sure you either get them from a GMPP dealer or make sure they are self aligning. The set you can get from a GMPP dealer will fit under the stamped rocker covers, and comes with nuts and locks.
The LT1 mini-ram style intake will probably help out your top end HP.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
TheExaminer
Sep 28, 2015 02:28 PM
neilb
Sep 15, 2015 05:06 PM
masonta
Sep 1, 2015 06:40 PM
