P/S High Pressure Hose
Old Feb 5, 2002 | 12:45 PM
simon's Avatar
I'm replacing my P/S pump and figured I should replace the high-pressure hose at the same time. I picked up a replacement at a local parts store. My question is this: why does the original hose have a sensor of some sort built into the hose? The new hose doesn't have this sensor or even a fitting for it? What is this sensor and if I unplug it from the harness what will this do the the comp? Thanks
Old Feb 5, 2002 | 12:57 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The sensor you are seeing is a high pressure switch designed to disable the A/C compressor when the P/S pressure gets too high. (like, when you have the steering wheel turned all the way to the lock.) This was originally intended to prevent engine stall if both conditions existed at the same time...... You may want to check with your vendor, and see if they have the hose with the fitting for the sensor.
Old Feb 5, 2002 | 01:42 PM
simon's Avatar
I called the dealer. The OEM hose is a whopping $71.99. I'm going to see if I can't just leave the current one on as its not cracked. I'll take back the 14.00 replacement hose. Thanks
Old Feb 5, 2002 | 03:14 PM
Guest
Guest
Posts: n/a
You should be able to get the right replacement hose from an aftermarket supplier. Try a different brand or look in the book yourself, someone probably missed that there were 2 different hoses used.
Old Feb 5, 2002 | 06:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Replace the hose. Use the one you already have.
Just put a jumper wire in the plug, and don't turn the steering wheel all the way to lock when the A/C is on.
Old Feb 5, 2002 | 07:43 PM
simon's Avatar
[Replace the hose. Use the one you already have.
Or else what - will the engine stall under these conditions? Thanks.
Old Feb 5, 2002 | 08:07 PM
Guest
Guest
Posts: n/a
Will it stall? I doubt it. My TA doesnt have a pressure sensor.
Old Feb 6, 2002 | 06:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My 83 Z28 doesn't have one. Any V8 should have enough .... ummm... reproductive glands to keep from stalling under those conditions.
Old Feb 6, 2002 | 05:09 PM
simon's Avatar
Then why was it there originally? I'm not trying to be a smartass - just curious as GM wouldn't spend money on something if they didn't have to...
Old Feb 6, 2002 | 05:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would suspect that they needed it for the 4-cyl and 6-cyl cars, so rather than having special lower-production pieces for the V8 cars, they used the same ones for them all... sometimes in mass production it's cheaper to make them all the same than it is to leave little stuff off of a few
Old Feb 6, 2002 | 06:57 PM
Z28DJP1987's Avatar
The high pressure hose with the sensor($71.99 from Gm) was used ONLY on the fast ratio PS boxes on the IROC's and not on
4 or 6 cyl. cars which used the $14.00 one.
Old Feb 6, 2002 | 07:47 PM
simon's Avatar
I have a '89 RS L03. So I guess it has the high ratio box which necessitates the hose with the pressure switch?
P.S. The hose itself is $71.99, the pressure switch is another $30 - nice huh.
Old Feb 6, 2002 | 09:12 PM
Guest
Guest
Posts: n/a
Hmmmm.
All 3 of my thirdgens had the high ratio steering boxes, and not a single one had the sensor. The LG4 in my dads Grand Prix with comparatively low ratio steering did have the sensor.
I dont think it has anything to do with high or low ratio, I think it has more to do with total power output and idle RPM, both of which are the lowest for a V8 with the LG4 and LO3.
Old Feb 7, 2002 | 10:35 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
My 92 RS (W/F41 Suspension) came with the pressure switch.I converted to braided stainless teflon-lined hoses a couple months ago and drilled & tapped a fuel pressure adapter block (-6AN)
to fit the switch.
Anyway, I was short one fitting when I put it back together and left the switch out, figuring I'd install it later when I got another hose end.
Hasn't caused me any problems, leaving it out completely.
-Rich-
Old Feb 8, 2002 | 10:22 AM
Vader's Avatar
My '86 TA doesn't have the pressure cutout, and it has the WS6/high effort steering box. It also has the 305 Teepee Eye, and you don't get much less power output than that...
I suspect there may have been several ThirdGen cars that had the switch, but would expect to see them more on V-6 and L-4 engines. Most other GM vehicles with smaller engines used the pressure cutout to prevent stalling under heavy steering loads at low RPMs. I know that my ECM doesn't even use the input, but some do.
bryanwood74
Sep 24, 2015 09:50 PM
lakeffect2
Aug 23, 2015 08:44 AM
TA8487
Aug 16, 2015 12:21 PM
jackhammer
Aug 15, 2015 10:04 PM
