Roller engine questions
Old Feb 5, 2002 | 06:44 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I'm shopping for a 350 and would really like to get a factory roller. I know the 87+ F-Bodies have them but what else did and what years? What compression were they?
How can I check if a hydraulic lifter is blown out?
Under what circumstances should I replace the lifters on the engine I buy?
Old Feb 5, 2002 | 09:08 PM
ede's Avatar
ede
any 87 and up sbc would be a roller cam engine. most likely you'll not have problem with a lifter being "blown out". usually there is wear befroe anything else.
Old Feb 5, 2002 | 09:34 PM
Car: '87 Camaro LT
Engine: 355 L98
are you sure all were roller? on the tech page it specifies that from 87 on only F Body SBCs were roller, not all SBCs, at least at first
Old Feb 5, 2002 | 10:04 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
My friend has an 87 Camaro Z28 4bbl and it is NOT a roller.
Old Feb 5, 2002 | 10:07 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
ALL '87 and later block were machined to accept the factory roller setup. Although not all came with the roller setup. I think anything '87 and later out of a CAR will be. I know the trucks are not all roller cam. Mine is not, but it does have all the provisions for the factory roller.
Old Feb 6, 2002 | 01:07 AM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
V8Astro is right the trucks V8s did not have rollers until 96
Old Feb 6, 2002 | 01:38 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
He's also right that those blocks have the provisions for the roller cam.
I'm building a 350 for my car now, and the block I have is a 638 casting # that came out of an '89 HD 3/4 ton. So it's also a 4 bolt main !!!
Now I have heard that not all the blocks have the holes drilled and/or tapped. Mine does, but I'm still being a cheap *** and not using a roller cam.
AJ
Old Feb 6, 2002 | 01:56 AM
long&low's Avatar
Engine: TPI 350
yep, the 87 truck block i am building now had the front drilled for the retainer plate, but I had to drill and tap for the hold down.
I bought a zz4 cam brand new for $50 so I decided to go roller
Old Feb 6, 2002 | 06:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have a block but no roller lifters, don't bother with the factory's freshman engineering student project of a "system"... get the kind of lifters that all the rest of us have been using for all these decades before the factory "invented" roller cams. They use link bars to connect the lifters in a pair for each cylinder, to keep them from turning. It's a whole lot more reliable than the stupid sheet-metal thing GM used.
Old Feb 6, 2002 | 06:50 AM
Car: '87 Camaro LT
Engine: 355 L98
So does anyone know exactly which cars (and years) actually came with a roller, not just setup for it?
Old Feb 6, 2002 | 11:07 AM
AJ_92RS's Avatar
Sorry. Should have answered that for you the first time.
Any GM car that had a v-8 after 87 will have the roller engine. About the only thing that didn't get the roller cam was FULL SIZE trucks.
But that really narrows it down to just a few cars that even got a Gen I, V8.
Camaro 87-92
Firebird 87-92
Caprice 90-92 for sure. I don't think they got roller cams until a little later.
Corvette 87-91
I'm sure there are others, but I don't know which Cadillac, Olds, and Buick cars had a 90* V8 before the Gen II (aka LT1) was released.
AJ
Old Feb 6, 2002 | 01:31 PM
Sparkee's Avatar
Only fuel injected cars got the roller cams. If it has a carb it is not roller. I'm not sure when the Caprices got rollers. Your best bet is to find a TPI motor from from a Camaro/Firebird. You probably won't find too many Vettes in the junkyards.
Another option, if you can't find a used one, is too get a roller cam/lifters for the older style blocks. They make kits that install with no machine work to your block. They are pricey, though. You can spend alot of money on a roller setup with very minimal power gains. Go with a good hydraulic flet tappet with some roller rocker arms, for the most cost effective approach. That's just my $.02. Later.
Old Feb 6, 2002 | 06:00 PM
Car: '87 Camaro LT
Engine: 355 L98
In the tech info it says in '87 ALL V8s got rollers, not just FI, who's right here?
Old Feb 7, 2002 | 08:32 AM
Sparkee's Avatar
I've got a 87 Monte Carlo SS, 305HO, V8 with the stock CC Quadrajet, and it does not have a rollercam. It also does not have the block machined to except a roller. I've talked to other people about it. 88 Monte's did not. 88 Caprice did not. I don't know about non TPI Camaros/Firebirds. Anyone with a TBI V8 have a stock roller cam? What year did the 3rd gen's give up on carbs and go to TBI? I wish my Monte had a roller, but it doesn't, yet. Later this year I am replacing the carb'd 305 with a 350 TPI from a 92 Z28. Then the real fun begins!! Later.
Matt
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
