bosch platinum or platinum 4???
Old Feb 6, 2002 | 03:27 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
whats up guys, i wanted to get spark plugs for my car and found out that the platinum run for 1.99 and the platinum 4 run for 5.99, now I notice a HUGE difference in the price- but is there a DRASTIC difference between the 2??? which do you suggest i get???
thanks
Old Feb 6, 2002 | 04:14 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Go w/ teh standard bosch platinums... theyre good plugs and unlike the +4's, they can be gapped
Old Feb 6, 2002 | 06:48 PM
89BlueTA's Avatar
Between the two I would pick the regular platinums, though I have switched from the platinums to regular NGK's which I like.
nick
Old Feb 6, 2002 | 07:03 PM
91fbirdgta's Avatar
i appreciate the suggestions guys, i'm goin w/ the reg. platinums
Old Feb 6, 2002 | 07:47 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I've seen test reports on the +4s and they suck. After a while the spark begins to jump to only one sidewire (path of least resistance) which carves a trench through the insulator, after that sidewire gets burned up the spark move to the next one until all four are burned up. In the process, the four piece of insulator pie break off and the sidewire also detriorates until it's buried way down in the insulator. In short you've spent $50 on plugs that break in your engine.
Old Feb 8, 2002 | 11:11 AM
pauls's Avatar
Thats a load! I,ve run Bosch 4's in 3 different cars for years. First, a 81 Monte, currently in my Explorer and my 3rd gen. They run great . Good throttle response, and long life. Especially nice in a vehicle thats hard to get at plugs.
Old Feb 8, 2002 | 11:40 AM
Car: '87 Camaro LT
Engine: 355 L98
I'm just telling you what the report said, pictures don't lie.
Old Feb 8, 2002 | 12:28 PM
silentneko's Avatar
I tried the bosch 4's they aren't very good. my rapidfires were much better and gave smoother power, plus only cost like $1.89. $5.99 for a plug is criminal, what a waste of money.
Old Feb 8, 2002 | 01:24 PM
82camaro's Avatar
Car: 82 camaro SC
The standard old ac delco's will work just as good. If you want longer life go with the platinum.
Old Feb 8, 2002 | 01:48 PM
Brian K's Avatar
I look ast it like this, I change my plugs every year.. Why waste 2 dollars or more per plug.. I use stock AC delco's gapped slightly bigger. It would be better to index your plugs instead of +4's or splitifres..
STOCK PLUGS RULE....
Old Feb 8, 2002 | 01:53 PM
ChevyLuva3's Avatar
Which is better to get, Platinum Professional plugs or Rapidfire Platinum plugs? Are they the same plugs?
Old Feb 8, 2002 | 02:11 PM
silentneko's Avatar
rapidfires are great plugs, I've used them in 3 cars and never had a problem
Old Feb 8, 2002 | 02:32 PM
FoREEL's Avatar
electricty travels the shortest distance between two points
Old Feb 8, 2002 | 04:59 PM
Little GTA's Avatar
I have used the +4s...I took them out...you want them?
When have you ever seen lightning strike in a perfectly straight line???
Old Feb 8, 2002 | 05:02 PM
85transamtpi's Avatar
Heres one more vote for good old delco rapidfires. In my opinion the best performing spark plug out there for our cars.
Old Feb 9, 2002 | 06:05 PM
87_Camaro's Avatar
delco rapid fires are the way to go.
Old Feb 9, 2002 | 06:47 PM
Vader's Avatar
ROFLMFAO! Great, dude! I couldn't have said it better myself, but not nearly as funny...
That covers it.
Old Feb 9, 2002 | 08:19 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
When I bought my 91 it had +4s in it. Didn't run bad or anything. Changed to regular AC Delco and it ran the same. I just won 8 free Bosch Platinum +4s matched to my car and they are still sitting on my desk. Maybe I'll put them in my car again just because they were free but I'd say stick with Delco.
Old Feb 9, 2002 | 08:53 PM
Vader's Avatar
Bosch makes wonderful fuel systems - almost as good as Rochester (if you doubt that, look at their mechanical injection system based on the "stolen" 327 RamJet system from 1964 - they offered them on Porsches in 1970-1978). Their electronics and electrical items are nothing to get all woody over, however. They are adequate, but not premier. Their spark plugs aren't bad, but there are others that are much better.
NGK has much better ceramics and electrodes. NGK has an excellent ceramics program, which is second to none. Many of you may have noticed that I'm not a big fan of our far-eastern competitors and their manufactured products, but I have to give credit where it is due. NGKs are very good spark plugs. They STILL don't offer a spark plug that meets FAA standards, but they probably could if they wanted to. That's likely more than I could say for Bosch, and I'm a second generation German immigrant son. I can't believe Bosch would even market such a snake-oil product as the +4, considering the risk to their reputation.
And Auburn doesn't offer plugs for the automotive market. Only Champion makes FAA-approved and automotive plugs, and they have a lot more experience in spark plugs than anyone else on the planet. This means they have the technology and ability to produce a very good offering.
I'll stick with the Champions for now. When Bosch GMBh starts offering sets like this, I'll be more attentive:
Old Feb 9, 2002 | 11:01 PM
Car: '87 Camaro LT
Engine: 355 L98
Vader, what do you think about Champions? I've never used them because I've heard they're garbage. I've heard their technology dates back to the 40s.
Old Feb 9, 2002 | 11:42 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
AC is the best for GM cars, but Im installing a set of NGK because they were recommended by Nitrous Express
amargari
Nov 10, 2015 02:09 PM
Nervous2
Oct 8, 2015 10:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
AmorgetRS
Sep 28, 2015 09:33 PM
scottmoyer
Sep 7, 2015 07:06 PM
