When is it time for new springs/studs?
Old Feb 6, 2002 | 07:52 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
How much lift is too much for stock springs and pressed studs?
Old Feb 6, 2002 | 08:40 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
If you are contemplating a cam change, then you are probably already in need for new springs. The studs are fine until you get into really high RPM and spring tensions. If you need to mill your heads for oversized springs, then you need to change to screw-in studs.
I'd say that if your valve lift is over .450" then you should look into different springs, or at least look carefully at spring bind. if you are going to rev the motor beyond 5000 RPM, get new springs. Buy the ones that are recommended by the cam manufacturer and you wont go wrong. (at least until you set up the springs!)
--Dan
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
