LT4 HOT cam too much for stock 350?
Old Feb 6, 2002 | 07:53 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Just like the subject says.
What if it had double hump heads?
Old Feb 7, 2002 | 02:29 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The LT4 HC will have too much lift with stock 350 heads if you are talking about an L98. I am not really sure what those camel-back heads can handle for lift in stock trim. Basically you will want to ensure that the retainer is not going to hit the guide boss as well as make sure the springs you choose do not bind no matter what heads you run. BTW, lift on the LT4 HC is .492" with a 1.5:1 rocker ratio and .525" with a 1.6:1.
Hope that helps
Good Luck!
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
NWAsonoma
Aug 18, 2015 05:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
