Cam Question
Old Feb 7, 2002 | 03:46 AM
86 IROCZ28's Avatar
Cam Question
I am thinking about changing the Cam in my 305 TPI MAP Camaro.
I wanted to ask what is the maximum Cam I can put in withought messing around with the PROM. What would be a good replacement as in Lift and Duration to get some HP increase and not have to worry about reprogramming my CHIP.
Current Cam specs as listed in the Tech section on this site.
LIFT DURATION
Int. Exh. Int. Exh. Separation Arm Ratio
.350 .385 178 194 109.0 (106/-112)
Thanks,
Mike
Old Feb 7, 2002 | 06:45 PM
jackdakilla's Avatar
u could use a stock LT1 cam...that would give u like 205 duration and .450" lift .....or comp cams makes a great cam with 206/210 duration and .450/.480 lift.....just keep the duration low and the lsa high and u should be ok with the stock chip!!
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
