i gotta problem with my starter...people say its my selonoid?
Old Feb 7, 2002 | 07:14 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
when i try and start my car it will crank a couple times then it will sound like the starter is missing the flywheel and u can hear the starter rev up really high........it does this all the time if i dont start within a couple cranks.......some people told me it is my selonoid??......is it?
or is it something else?
thanks
Old Feb 7, 2002 | 09:32 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like the bendix or solenoid.
I make it a habit to always replace the starter AND solenoid at once, never piece by piece.
Old Feb 8, 2002 | 04:17 AM
Jza's Avatar
Jza
If the solonoid is out, the starter will spin, but the solonoid will not push the gear out to engage with the flywheel teeth, thus the revving sound.
Old Feb 9, 2002 | 10:04 AM
TBI305Camaro's Avatar
could need new brushes kinda sounds like the overrunning clutch may be bad its hard to tell...you can go get a "rebuilt" starter at advanced with a lifetime warrenty for like 25$
Old Feb 17, 2002 | 06:32 PM
Rough84Z's Avatar
I have had a lot of problems with my started until I discovered that a bracket was missing. It would keep kicking sideways throwing off the spacing and causing it to grind the teeth. Adjust / install your starter so that it works and measure the gap. If it starts to grind, measure the gap again. If it is in fact moving, you will need to find or make a bracket to keep your starter from pivoting on it's mounting bolts. This is what I did after going through 5 different starters and now I have no problems with it at all.
Old Feb 17, 2002 | 06:36 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Definitely sounds like the bendix or solenoid to me too. As mentioned earlier, you can get a rebuilt starter with lifetime warranty very cheap.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
