It's knockin and I dont know to answer
Hey I got a LB9 and I put on headers well I finally finished the exhaust and now that its quite I got a ticking sound coming from drivers side of engine...it sounds like an exhaust leak, but its not. I listened closer and it has a knock with the tick too. I took off my rocker arm covers and tpi runners and didnt see anything out of the ordinary. Any one got any ideas???????
Tightening the nuts on the rocker arms to a certain spec so they don't rattle. There's two ways of doing it: one with the engine off, and one with the engine running. The latter is easier and quicker, but messier as well.
FoREEL...do you have an oil pressure guage? What's your pressure at while idling hot? Although you can have a bad main without losing much pressure you will see a difference from how it is slightly.
Start by pulling i wire at a time from the cap & see if the KNOCK goes away. Put it back if it doesn't. Do this for each cylinder. If it stops, you may have spun a rod bearing.
Make sure it IS A KNOCK though. a tick is VERY different. Knock sound like a faint (or loud) It's like a hollow sound. Tick/click is exactly how it's specified!
Get back to us.
Get back to us.
HoosierinWA
Oct 7, 2015 10:15 AM
