What is max lift for stock valvesprings?
Old Feb 10, 2002 | 09:53 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Checking for a friend of mine that has an 86 T/A 305TPI that he's getting a new cam for.
What is the max lift that the stock valvesprings will handle??
Thanks,
Ken
Old Feb 10, 2002 | 10:02 PM
88TAJeff's Avatar
Car: 88 T/A
Check the cam in my sig. That's with stock springs, but some say it might be pushing the envelope a little.
Old Feb 11, 2002 | 04:52 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Generally, the max recommended is in the .450 range, give or take a few thousandths.
Old Feb 11, 2002 | 04:54 AM
ede's Avatar
ede
it wouldn't matter to me when i change cams i change springs and trash the stock rotator set up. i'd think .450 would be the top limit for stock springs.
Old Feb 11, 2002 | 08:34 AM
Vader's Avatar
O.K. - I'll jump on the wagon, too.
0.450" is safe with stock springs, but not much more. And that isn't only because of coil bind and interference, but the seat pressure of stock springs is generally inadequate to control the valve train when a cam with .450 lifts or greater also has a ramp profile that creates a lot more linear accelleration of the valve (because of the greater travel distance over the cycle time). Valve float and seat bounce can start to be a problem at higher RPM ranges, and the extra heat generated by the longer motion is tough on stock springs. Couple that with the extra mass of the stock exhaust valve rotators and spring shields, and the stock setup gets very marginal above .450" lifts.
.450" is not just some arbitrary number thrown out as a reference - there are some reasons for it and it's been a while since anyone has posted those. It's generally better to not only understand the "what", but also the "why".
Old Feb 11, 2002 | 08:38 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Any reasonably streetable hydraulic cam for a 305, will
have a valve lift under .500". As far as coil bind interference
is concerned, your stock springs will handle this to about 5500rpm. But for maximum rpm potential you might want to replace the stock springs with a stock diameter (1.26") replacement high perf spring. You can buy them from various manufactures.
Crane, Comp cams, GM, Isky, K-Motion. Look for something with
about 100/120 lbs seat pressure and 290 to 340lbs open pressure.
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
NWAsonoma
Aug 18, 2015 05:45 PM
