valves tapping help me
Old Feb 11, 2002 | 09:45 PM
BowtieFever's Avatar
hi my friend has and 85 z28 350 carb. and his valves tap very loud after a couple minutes you can tell some of the valves stop tapping but some still do on the passenger side, the drivers side dont. please help me could it ce from not getting enough oil
thanks alot
Old Feb 12, 2002 | 03:25 AM
89 3rd Gen TA's Avatar
if the oil pressure is fine..then usually that's not the case...try to tighten down the valves slightly...before u bend a valve.
Old Feb 12, 2002 | 03:33 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
cam going flat eeeooo. how many miles, how many oil changes?
gta892000
Sep 16, 2015 12:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
