What size diameter flexplate (flywheel)
Old Feb 12, 2002 | 03:39 PM
chitownGTA's Avatar
I am starting an engine swap and thinking about ordering an SFI approved flexplate for use w/ the stock TH700.
wondering what diameter that is? (I thought 12.5")... will be going in an 89 TA
Thanks for any help
Old Feb 13, 2002 | 01:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They are usually referred to by the number of teeth.
You want 153 teeth for the stock-type starter (I believe that is 12-1/2"). You also need to keep the rear main seal type in mind, as the two different crank types use different flex plate mounts.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
84LsxZ28
May 17, 2020 02:21 PM
PurelyPMD
May 5, 2016 04:57 PM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 7, 2015 08:08 PM
