305 pistons?
Old Feb 12, 2002 | 04:54 PM
V6camaroman's Avatar
305 pistons?
does anybody make a higher compression piston for the 305? i was looking for something between 9.50 to 10.00. what cc is a stock 305 head? 64 or 76cc
Old Feb 12, 2002 | 05:07 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I know the '88 5.0 HO on my GTA came with stock 9.5:1 pistons. As far as a source for replacements I have not searched.
The 305 heads are 58cc.
Old Feb 12, 2002 | 06:29 PM
sleeper's Avatar
the 305 HO heads are 64cc
Old Feb 13, 2002 | 12:53 AM
ryan1488's Avatar
http://www.kb-silvolite.com
thats where i got mine
Old Feb 13, 2002 | 08:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There was no 305 HO in 88; that was a carbed motor, RPO L69, and the last year was 86.
305 HO heads (casting # 416) are 58cc. Most of the rest of the 305s used in F bodies AFAIK are also 58cc.
Federal-Mogul markets hypereutectic flat-tops for 305 under their Sterling brand name. Summit carries them. Use their site, you'll find them easily.
Old Feb 13, 2002 | 11:32 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Oops! I stand corrected. (5.0 TPI)
Old Feb 13, 2002 | 01:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With standard flat-top, 4-valve-relief pistons, steel shim head gasket, stock 305 heads (all factory 305 heads were 58cc, by the way), you'll get 9.5:1 compression.
Use a standard replacement composite head gasket, you'll lose a tenth or so CR. I believe JC Whitney lists 10:1 305 pistons with a slight dome. Others probably make them as well.
All 3rd gen carb engines after '85 had flat tops. All 305 TPI engines had the same 9.5:1 CR using flat tops.
If I was faced with the expense of buying pistons for a 305, I'd go get a 350 instead. But, that's just me.
Old Feb 13, 2002 | 01:35 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
i have the stock heads on my car, 82 305 with flattops, no valve reliefs, and the machine shop said they were 10-5.1, i may be wrong but i thought after 85 with 9-5.1 had a slight dish on them oh well, oh and i tried to go with a 350 9-5.1 comp, 202 heads and everything else was the same (center manifold, carb, distributor, and the cam) on my 305 and my 305 would run side by side with it, now the 350 has a oil pressure prob with it so i am putting the 305 back on.
Old Feb 13, 2002 | 02:19 PM
camaro6spd's Avatar
The 87 TPI that came out of my car has flat tops and 4 valve reliefs.
Old Feb 13, 2002 | 05:23 PM
camaro03's Avatar
Car: 1982 camaro
what cc chambers did the 82 lg4's come with, could me not having valve reliefes effect compression?
Old Feb 13, 2002 | 06:37 PM
five7kid's Avatar
The '84-earlier LG4's had dish-topped pistons, same cc chamber in the heads. The dish is as deep (at least) as the valve reliefs, so no extra reliefs are needed.
Yes, dish-topped pistons will lower compression.
Old Feb 13, 2002 | 07:18 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
The figures I saw stated compression at 9.3:1 ???
Robert
Old Feb 13, 2002 | 07:36 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Are the silvolites any good?
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
