who makes std. diam. high lift springs?
Car: '87 Camaro LT
Engine: 355 L98
Who makes standard diameter (1.25") valve springs for lift over .490"? Summit has some for up to .490" but the LT4 HOT is .492" and I don't want to mill the seats for a wider spring.
Or can I use a wider spring without milling?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
you can get a dropin spring from comp-prdcts
that will go .6 lift
http://www.competitionproducts.com
http://www.competitionproducts.com/page24.html
Car: '87 Camaro LT
Engine: 355 L98
Thanks.
Will the LT-1/Z-28 springs fit an L98? They're the same diameter but I'm not sure about the height.
Are they just stock LT-1 springs that I can get from the dealer or are those aftermarket springs for LT-1 not available from dealer?
1988iroc350tpi
Aug 14, 2015 07:52 PM
