Stock retainers and 105 lb valve springs...
Old Feb 15, 2002 | 05:30 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Will that work? I was just looking at the price of comp cams retainers and keepers. $60 a set and I need two sets. $120 for glorified washers!?!?!
Can I use the stock retainers and keepers? The valve springs I already bought are 105 lbs seat pressure and stock (1.250") diameter.
Old Feb 15, 2002 | 06:23 PM
Vader's Avatar
Astro,
The stock keepers and retainers are not usually a weak point, unless the RPM gets stupid. Although I'm sure it's happened, I've never even heard of a retainer failure that wasn't caused by spring failure first.
The 105# of seat pressure isn't that great an increase over the stock 85 or so. I'm thinking you should be O.K. as long as the mass of the valves isn't over 130 grams for use at over 5,500 RPM. Above that mass at that RPM, the 105# springs with heavier valves may float on any kind of "performance" cam grind (something with valve acceleration rates above 0.005"/°).
Old Feb 15, 2002 | 06:58 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks Vader.
I plan on having my redline at 5500 rpm, or less depending on where the cam stops pulling. It isn't a crazy cam grind so I think I'll be ok.
1992 Trans Am
May 10, 2023 07:19 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
mustangman65_79
Aug 8, 2015 01:18 AM
