Engine RPM increase when brake pedal depressed
Old Feb 16, 2002 | 02:34 PM
simon's Avatar
My power brakes aren't all that powerful. I was curious if I might have a vacuum leak. With the vehicle in park I noticed if I pump the brake pedal a couple of times the RPM will go up. Is this normal? Is this any indication of a vacuum leak or a bad booster?
Old Feb 16, 2002 | 03:10 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
if ya pump em rapidly rpms will increase-to check booster integrity A)pinch vac.line to booster while running and note any rpm change. B)with engine off park car for an hour come back-pull ck.valve out of booster grommet should still have vacuum within sounds like whoosh.
Old Feb 16, 2002 | 04:02 PM
simon's Avatar
Grumpy - I'll give your tests a try.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
