help w/ timming
Old Feb 16, 2002 | 06:01 PM
Cyclops's Avatar
help w/ timming
I know that when you time a TPI unit you're supposed to disconnect the blk/tan wire. Every time I try the car dies. If it is disconnectecd the car wont start. When I put the timming light on with the wire hooked up it reads about 50degrees. Can anyone please help me????????
Old Feb 16, 2002 | 10:50 PM
Vader's Avatar
1-I,
Your procedure is correct for an '85 TPI. Disconnect the ESC bypass connector (tan/white wire) then set the base timing.
That "50°" thing is really weird, though. The car should start and run with the bypass disconnected, although it will run a little poorer. You probably should check the static timing of the distributor to see just how far off it really is. When you remove the distributor cap and rotate teh engine to the TDC position on the #1 cylinder (compression stroke), the rotor should be physically pointing toward the #1 cylinder. If it's 50° off (advanced), the rotor will be pointed closer to the left side of the engine. The ESC shouldn't be changing the timing that much unless there is a problem with the detonation sensor, sensor wiring, or the ESC module itself.
Something certainly isn't right.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
ausrs
Jul 4, 2001 10:06 AM
