Non-3rd Gen; Correct wheel nut torque?
Old Feb 17, 2002 | 07:29 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
My dad had the rear wheel off of his '67 Camaro SS, and I need to put it back on to move the car. What is the correct setting on my torque wrench to use to tighten the wheel down? They are aftermarket aluminum wheels, if that matters.
Old Feb 17, 2002 | 09:49 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
70 pounds feet is all that's required.
Old Feb 17, 2002 | 10:47 AM
Vader's Avatar
That may be correct, but it can depend upon the wheel, and sometimes even the hubs/brakes on the car. I've seen some alloys spec'ed at 105 lb/ft with FWD and solid front rotors (weenie little Chrysler hubs).
Old Feb 17, 2002 | 11:01 AM
ede's Avatar
ede
i use 85 ft/lbs when i put wheels on, unless i know differant, like my weld pro stars on my 85 camaro thake 65 ft/lbs.
Old Feb 17, 2002 | 06:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
But he never asked about that. 67 Camaro should have 7/16" wheel studs. That spec is 70 pounds of torque and 70 pounds won't hurt the aftermarket rims.
1992rs/ss
Jan 31, 2025 05:10 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IroczFan
Oct 6, 2015 10:13 AM
Omega
Oct 1, 2015 02:20 PM
