Crank Pullies
Old Feb 17, 2002 | 06:44 PM
StocRoc's Avatar
Crank Pullies
What is the best way to keep the crank from turning when changing the crank pulley? I have heard of sticking a screw driver in the flywheel somewhere. How would you do this exactly? Any better ways to keep the crank from moving?? Thanks
Old Feb 17, 2002 | 08:00 PM
Audiman's Avatar
You can have someone hold the flywheel with the turner or you can pull the valve cover loosen the two rockers on 1 or rotate the engine until they are closed and introduce air out of the compressor to the cylinder. This will charge the cylinder so the piston cant move up the cylinder you have to make sure the piston is before TDC though.
Old Feb 17, 2002 | 10:44 PM
bradkeith's Avatar
Try using an impact gun. Always works for me.
Old Feb 18, 2002 | 03:30 AM
Audiman's Avatar
Whatever works if you got the room.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
