383 stroker help
Old Feb 18, 2002 | 11:25 AM
Muzzs Ro's Avatar
383 stroker help
Hey, I'm still relatively new to engine building, so I was just looking for some advice. I have the block from an 84 vette, and I'm going to turn it into a 383 stroker. I already have the machinist lined up and everything, I just need help figuring out what kit to buy.
If anyone has any strong reccomendations about where I can get a good stroker kit for less than $1500 bucks, that would be nice.
I'm not looking for forged everything, I just want something that will put me around 400-450 hp without putting my credit card over its limit.
peace
Muzz
Old Feb 18, 2002 | 02:13 PM
Guido's Avatar
Car: 2000 Trans Am
Moving this to the general engine area. You will get more feedback there.
Old Feb 18, 2002 | 03:26 PM
FstBrd6point3's Avatar
I just had mine built, and with forged internals and and labor it cost me 3500, but I got charged only 50 an hour as aposedf to 65 cuz I knew the guy. One warning I should give to you that was given to me by my mechanic is you get what you pay for. If you buy a really cheap kity it is going to cost you a fortune to have it balanced. and the MOST IMPORTANT part of an engine like that is the bearings, don't sheap out, they are cheap to begin with, but use really good bearings. that is all the advice I have. good luck
rhuarc30's Avatar
If all you want is 400-450 hp you can get an entire short block for less than 1500 if you shop around, for that kind've power level you don't need anything fancy. If you've already got the block, If you can reuse the stock rods, crank will run you around 350, and a set of hyperuetectic pistons for a couple hundred and your set to go.
John
Old Feb 18, 2002 | 03:43 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
send this guy email
he will give you a quote for a complete assembly.
http://cgi6.ebay.com/ebaymotors/aw-c...serid=dynoflo1
You might want to send it through his web site at
http://www.dyno-flo.com
so they don't get ansy on ebay.
this guy also has some decient deals.
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1806437129
Old Feb 20, 2002 | 09:29 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
is the 84 the one they didnt make or is it the cease fire injection one?
Old Feb 20, 2002 | 10:22 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
83 was the none production and 84 was the cross flood injection.
Old Mar 2, 2002 | 02:11 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
thanks, and for those of you that for some *** awful reason have cross fried injection, check this out. http://www.rock-it.com/EfiMainPage.htm or this http://www.rock-it.com/CorvetteCrossfileECMUpgrade.htm
Old Mar 2, 2002 | 02:32 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Check out Jeg's they have Eagle stroker kits that are within your price range. I'm also curious if you're going to use fuel injection or a carb for this motor, that'll make a big difference in the power you make, and if you use the FI, it'll cost more for it to make the power that the motor is capable of.
Old Mar 2, 2002 | 08:42 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
check out http://www.speedomotive.com/
Old Mar 2, 2002 | 09:16 PM
SoCo80p's Avatar
i got a good 400 crank balance and flexplate for the 383 stroker setup you can have for 300$, you can reuse your stock rods and just get a diffrent piston, this is the cheapest way to go, no need for insane exotic stuff untill your realistly over 500 HP
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
