Evap canister purge valve
Old Feb 18, 2002 | 01:18 PM
88camaro's Avatar
what the hell is it , whats it do , why is it getting warmed up, and why when i disconnect it nothing changes , and WHY doesnt any autoparts store will know what the hell im taking about when i tell them im looking for an EVAP canister purge valve , whats the general term for this sensor thingy
Old Feb 19, 2002 | 12:16 PM
88camaro's Avatar
can anyone help>???>>????
Old Feb 19, 2002 | 12:50 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if im not mistaken, the EVAP purge valve opens to allow the unburned fuel in the charcoal filled cannister to be sucked up by the engine and be burned, i think. If you really dont care about your HC's on start up and inspection isnt a problem, you can just do away w/ the whole evaperative emmisions system and just plug the vaccume inlets on teh tb or manifold
Old Feb 19, 2002 | 04:00 PM
88camaro's Avatar
i actually thought it might cause some engine stumbling , so , can i just rip that thing out of there ?
Old Feb 19, 2002 | 08:56 PM
Car: 88 Camaro SC
Engine: SFI'd 350
go for it... it just captures unburned fuel to be burned on teh next engine start up... It reduces HC emmisions. just pull out all the hoses and the stupid black canister (making sure to plug the inlets and outlets) and your good to go. Emmisions inspection, if aplicable to you, could be a problem. they will fail you on teh spot for not having it and possibly fine you for tampering w/ the emmision systems. It is, after all, a federal offense. Not that that actually stops people from removing that usless clutter from the engine bay.I believe it wont trip any trouble codes but unplug the wire harness first to be sure.
P.S. Make sure you, or someone you know, knows how to properly do this.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
