Harmonic Balancer Question
Old Feb 22, 2002 | 08:30 PM
NORT's Avatar
I am in the process of putting a new or different 350 in my car. It is a 4-bolt 350 with a one piece rear seal. I found out today that I had to have a different flex-plate, an externally balanced one, I had a two piece seal motor before. The big question is will the balancer that was on my old motor work?? I know that there are internally balanced balancers and external ones, the one that I have is a stock 6 3/4 balancer and is just fine so I hope that I don't have to get another one!!!!! If there is someone out there that knows what the deal is please let me know, I don't want to mess up a new motor!!!!! Thanks NORT
Old Feb 22, 2002 | 10:20 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the balancers interchange, just the flexplates don't.
Old Feb 22, 2002 | 10:22 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The harmonic damper you describe is from a 305. 305's & 350's are internally ballanced. The damper will work the flexplate / flywheel will not. I would reccomend getting a 350 8in damper so you can use the 3 O-clock timing position. The hardest part with using a 6in is finding where the timing tab should be located.
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
