Part # for S/R Torquer heads?
Old Feb 23, 2002 | 08:28 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I have an '87 LB9 (305 TPI) Z28, and I'm not sure on which head is for me. http://www.worldcastings.com/docs/catalog/pg08.pdf I looked on this, and I'm pretty sure I need the last one, number 042650-2, right? Thanks.
Old Feb 23, 2002 | 11:35 PM
rezinn's Avatar
You want 58cc heads from http://www.worldcastings.com/docs/catalog/pg09.pdf
Old Feb 24, 2002 | 12:38 AM
Hg's Avatar
Hg
Car: '87 Z
Oops, linked to the wrong one, that's that page i meant to link to. I need the last one right? 042650-2 I think it is...
Old Feb 24, 2002 | 03:25 PM
Hg's Avatar
Hg
Car: '87 Z
BUMP
Old Feb 25, 2002 | 09:13 AM
Beefy89's Avatar
www.competitionproducts.com Won't find them cheaper.
Old Feb 25, 2002 | 03:25 PM
GreenProStreet's Avatar
It wont be too much of an improvement. They are designed as replacement iron heads, cast in alluminum. Just a worning; flow difference is minimal!
Old Feb 25, 2002 | 08:04 PM
Hg's Avatar
Hg
Car: '87 Z
Huh? The S/R Torquer 305's are cast iron, and i'm (hoping) to get them and put them on an LB9 which also is cast iron heads.
Old Feb 26, 2002 | 06:51 PM
They can be both. Why would you just want to buy replacement heads when you could up grade for almost the same amount of money?
Old Feb 27, 2002 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exactly what are you comparing them to?
They are only available in cast iron (S/R's are not available in Al). They are an upgrade over any factory 305 head.
However, they do benefit from bowl cleanup at a minimum. Every magazine article I've ever seen did that before any testing of any type, and even World recommended it when I asked them if I should do anything. That hardly qualifies them as "just replacement heads", though. Unmodified, they flow 213/166 @ .500" lift - good luck getting swirl port heads to flow that much. Figure at least 10% improvement if you do the full Standard Abrasives treatment on them (probably more).
On a TPI engine, Pop Hot Rod gained 50 hp over fresh 3-angle valve job factory LB9 heads - that was with pocket porting only, and a cam similar to a stock cam. With a better cam, the improvements will be even more. Add to that: able to handle higher valve lifts, screw-in rocker studs, and generally higher quality castings than factory. They can be installed without shaving to get the chamber volume down, have exhaust cross-over passages, are available to bolt to either style intake bolt pattern, will take perimeter or centerbolt covers, etc.
Oh, I think you want 042750 heads for '87-later intake style. -1's have regular valve springs, -2's the larger diameter types.
I know I tend to "sing the WP praises", a little too much some may say, but at least I'm basing my opinion on published figures and direct experience.
BTW, if these are just "replacement" heads, what would you call an "upgrade" head for a 305?
Jake_92RS
Jan 28, 2020 10:37 PM
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
