pushrod question
Old Feb 26, 2002 | 11:56 AM
BlackBird92's Avatar
Car: 1992 Firebird
Engine: 305 LO3 TBI
pushrod question
Hi everybody,
I just got my comp magnum roller tip rockers and, according to comps website, I thought them to be a simple bolt-on.
But other than on their website, comp states in their installation instructions, that one should/must use new push rods with their rockers.
Other than some light mods, my enginge ist stock (see my sig)and has 67.000 miles.
Is it mandatory to use new push rods?
Does anybody here have these rockers installed using the _used stock pushrods and having any trouble with this combination?
Or do you generally install new rockers with new pushrods?
My Haynes manual doesn't say anything about this.
I am a little impatient putting them finally on, but OTOH I don't want to ruin them with my impatience.
Thank you,
A.
Old Feb 26, 2002 | 12:08 PM
Nordbert's Avatar
Factory pushrods can wear at the tip and break. The end of the pushrod can then wear through the socket of the new rocker
arm . Since I can buy them locally for cheap, I would put in
new ones.
Old Feb 26, 2002 | 01:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Did you get the 1.6:1 ratio rocker arms?
If so, then 'Yes". You must change the pushrods.
In order to obtain the higher ratio, they have to move the pushrod position closer to the rocker arm stud. By doing that, it changes the length of the pushrod needed to keep the valvetrain geometery in line.
If you ordered the 1.5:1 ratio arms, then maybe they're suggesting you use hardened pushrods? I dunno on that one.
Best thing you can do is call/email their techline and ask them.
AJ
Old Feb 26, 2002 | 04:05 PM
rezinn's Avatar
When I installed 1.6 roller tipped rockers I put .1 or .25 inch (can't remember, maybe not even that) longer than stock hardened pushrods in, I needed hardened ones because I was using guideplates. To check exactly for needed length people will tell you that you really need a pushrod length checker. I just guessed from what I had read, and it worked quite well. Those chromemoly comp cams rocker arms are good quality.
Old Feb 26, 2002 | 08:34 PM
Car: 1992 Firebird
Engine: 305 LO3 TBI
Thanks for your replies guys!
@nord: sounds reasonable what you are saying. It's a good argument for new prs. I was just confused about the fact, that comp is saying "direct replacment bolt-on for stock rockers" on their website and in their installation instructions they say something similar to what you do say. I think I'm gonna get a set of new pushrods tomorrow.
@aj:nope, they're 1.52 and comp doesn't suggest hardened pushrods in their installation instructions. I don't think the techline will help much. I'll better go safe and get new ones.
@rezinn: thanks for your response, too, man. But since I don't have 1.6s I won't need longer than stock pushrods.
A.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
