neccesary to put bolt back in?
Old Feb 26, 2002 | 04:48 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
after smog pump removal should you put the top bolt back in ,the one that goes into the head............for purposes of strengthening the ac bracket? i was thinking when i get aftermarket heads i doubt they will have this hole in it.....wondering what you guys have done and if you ever have a problem with that bracket coming loose..........
Old Feb 26, 2002 | 07:07 PM
89BlueTA's Avatar
I forgot to put that bolt back in my car, when I took the AIR off and did not have any problems. Though I did put it back when I realized it was missing about a year later. The heads you order should be drilled for all acc. bolt holes and at the very least you can request it.
nick
sailtexas186548
Jan 19, 2016 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
