Do I need a carb spacer with this setup?!
Old Feb 27, 2002 | 11:56 AM
383 Smoka's Avatar
Got rid of my old Weiand Intake, thru on an Edelbrock Performer Intake and have the 1405 Edelbrock Carb.... Do I need a spacer? With the Weiand I was using a spacer, just wondering if it is still needed? Thanks....
Old Feb 27, 2002 | 12:19 PM
firerider76's Avatar
Car: 1986 Trans Am
The answer to your question is NO.Just run the carb on the performer intake.Edelbrock designed them to work together.
Old Feb 27, 2002 | 04:22 PM
Stroked-Z's Avatar
383 smoka if you have a 383 you will need much more than just a regular Performer intake to make that engine breathe. We like to breathe, unfortunetly alot. Thats why the best bang for a buck on a 383 is a good set of heads.
List your engine specs & vehicle specs & we'll see if you will benefit from that spacer.
Old Feb 27, 2002 | 06:04 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I think I am gonna go with Stroked-Z on this and say that you likely don't have enough intake or carb for that engine to realize it's full potential - depending on heads and cam of course. Need specs......
Old Feb 27, 2002 | 06:32 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Boy you were dead wrong. 4 posts...go figure.
You should have gotten the performer RPM. It all depends on what cam and heads you running like previously said. But I'm almost positive that a little more carb and a higher rise would help. what are the specs???
Old Feb 27, 2002 | 10:25 PM
383 Smoka's Avatar
I no longer have the 383.... Im running a rebuilt 350 originally from an EL Camino.. Im not sure whut heads it has but it has roller cam, chain, and 1.6 rockers... Performer intake, 1405 performer carb..... I talked to the dudes at edelbrock and they said with the intake and carb, i dont need a spacer?!
Old Feb 27, 2002 | 10:32 PM
87_Camaro's Avatar
well with a 350 it's a different story, well what kind of spacer is it!? like a 1 inch spacer, if thats the case then it's for atomization purposes and that ='s more hp so I would leave it on, but its it's somethin different then i wouldn't know.
Old Feb 28, 2002 | 12:53 AM
383 Smoka's Avatar
Its like half an inch....
Old Feb 28, 2002 | 05:55 AM
ronterry's Avatar
Car: '94 Corvette
Besides allowing the air more distance to turn into the runners, some spacers create a heat insulator between the carb, and intake. This can reduce vapor locking, and allows a cooler charge to enter the intake.
With the Performer, YOU MUST USE a divided spacer, and not an open spacer.
Ron
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
