effects of larger sprk plug gap
Old Mar 1, 2002 | 06:47 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
How does having a larger spark plug gap benefit performance when you have an ignition system powerful enough to justify a larger gap.
And, if you can have a bigger gap and don't do it, what are the drawbacks to that?
:hail:IROC-Z
Old Mar 2, 2002 | 08:56 AM
ede's Avatar
ede
larger gap means a larger surface area of the spark, more spark area to light the a/f mixture. you need a stronger ignition system or you get a weaker spark as the gap increases
Old Mar 2, 2002 | 02:35 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Your stock coil puts out about 37K volts. By going to an aftermarket coil (MSD Blaster 43K) (HyperTech 53K) and increasing the gap you will expose more spark as Ede says. Further you can grind the electrode back then set the gap to .50 to expose even more.
<img src=http://www.gmtips.com/3rd-degree/dox/tips/ignition/plug.jpg>
This is a win/win/win/win modification IF you have a high output coil.
1. It's free.
2. More power.
3. Better gas mileage.
4. Less emissions.
Old Mar 2, 2002 | 04:34 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Thanks for the info and pic guys. That's a cool idea about trimming the electrode back.
:hail:IROC-Z
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
Thornburg
Sep 1, 2015 03:39 AM
downsouthboy
Aug 29, 2015 11:29 AM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
