center/perimeter bolt valve covers?
Old Mar 2, 2002 | 12:16 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Are perimeter bolt valve covers higher than center bolt covers?Will perimeter covers clear the serpentine belt brackets?
Old Mar 2, 2002 | 03:26 PM
GreenProStreet's Avatar
Can be, and should, depending on which you get.
Old Mar 2, 2002 | 03:54 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I have stock center bolt heads now Im going to order a set of trickflow 23* and are wondering if I get the perimeter cover heads if they are going to hit any thing? The center bolt covers come real close some of the brackets.
Old Mar 3, 2002 | 09:03 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
valve covers
I have a 91 Z-28 TPI. It has trick flow heads and centerbolt valve covers and it clears everything ok. But one thing you have to watch out for is that I have summitt aluminum roller rockers and the valve cover bolts were hitting the rockers and gouged them up pretty good.
Old Mar 3, 2002 | 09:26 AM
e-man's Avatar
Car: 89 formula
Engine: 383
PaveTim did you need a longer or shorter set of pushrods? Stock cam or aftermarket cam?
Old Mar 3, 2002 | 10:11 AM
jamesbern's Avatar
Tall perimeters will hit the alternator bracket and the positive stud on the alternator, but with some quick grinding this is solved. On the rear passenger side they will hit the A/C box, this can also be solved with some grinding.
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
