Setting Hyd. Rockers
Old Mar 5, 2002 | 01:15 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have seen so many things said about setting the rockers on a Hyd. roller cam. I have heard that tighten them down and when you feel drag on the pushrod then go 3/4 turn........Any help will be appreciated.
Brian
Old Mar 5, 2002 | 01:44 PM
rezinn's Avatar
What I do is tighten them down until the pushrod will no longer spin, and then go about a quarter to half turn more. You have to make sure that the lifter is touching part of the cam lobe that is NOT opening the valves when you do this, otherwise when you crank the engine you will have a lot of loose valves and the car will run badly. An easy way to do this(the lazy way) is to adjust all of the valves at once, then turn the engine over a quarter of a turn and readjust the loose ones. If you do this until none are loose, you should have it. Of course if you can somehow see the top of the lifter resting in its bore through the head(some heads are like this), then you can easily adjust the ones that are on the flat part of the lobe, crank the engine, and do the rest.
Old Mar 5, 2002 | 02:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Now, I am lazy, but I never thought of that one before!
Should work. Won't do an intake when you intended to do an exhaust, won't forget one, etc.
I agree with the 1/4 to 1/2 turn down as well. All adjusted the same, whichever you choose, of course...
Old Mar 5, 2002 | 02:34 PM
if one was too tight would it cause a miss........the valvetrain is quiet. I have crane full roller with poly locks.
Thanks for the help
Brian Felts
Old Mar 5, 2002 | 06:35 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i did mine by starting the engine with em all loose............tightened em till the tapping went away went a half turn and finito................
Old Mar 5, 2002 | 07:40 PM
WASP..............how did you keep the oil from blowing out on the motor and you? I would like to do it that way but I was told it was very messy.
Brian
Old Mar 5, 2002 | 08:15 PM
bradkeith's Avatar
I set mine the same way WASP did. It's been done like that for years. If you run ahigh output oil pump and want to keep it from splashing everywhere, you can buy rocker arm clips to deflect the oil. maybe $20 for them.
Old Mar 6, 2002 | 12:58 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I bought mine for $6 and theyre great. (rocker arm clips that is)
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
