Will this oil pan fit?
Old Mar 6, 2002 | 05:58 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Can anyone tell me if this pan will fit around the crossmember? It will be going on a 406 SB, Drivers Side dipstick.
http://www.jegs.com/cgi-bin/ncommerc...711&prmenbr=76
Also, can anyone reccomend a very good oil pump? I dont want the VERY best, but one close to it for a reasonable price. Thanks!
Old Mar 6, 2002 | 06:36 PM
GreenProStreet's Avatar
Moroso pans are pretty much universal, so unless you have a first gen Nova, then it will pretty much always fit.
The best oil pump is the stocker!!!! I dont know if you are running a roler cam but higher volume/pressure pumps cause lost performance and sometimes breakage of the stock lifters. A stock pump with a '69 Z28 pump spring will suffice an engine to 7000 rpm or 800 hp, whichever comes first!
Old Mar 7, 2002 | 08:17 AM
Scott_92RS's Avatar
Car: 1992 RS
Thanks for the info. I'm gonna go ahead and buy that pan today (along with a whole slew of ARP bolts $$$ ) Where can I get a regualr old stock pump? Do I have to buy it from a dealer? Also, where can I order the 69 Z28 Pump Spring? Thanks so much for the help.
Old Mar 7, 2002 | 09:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I agree with Green on pump choice: my favorite for a street motor is a plain old M55, with the screen to fit the pan you are using, and the Mr Gasket #26 spring. That pump makes about 30 psi idling and 55-60 cruising in a motor built with stock oil flow (bearing tolerances, hyd lifters, etc.) and 5W-30 oil.
Unless you are doing something that drastically increases the flow rate within the pressurized oil system, a stock pan is just fine. Your money would be better spent elsewhere. A typical street motor doesn't need anything beyond that, except maybe a windage tray.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
gwade12
Aug 8, 2015 08:17 AM
