Differences b/w 305 and 350 crank
Old Mar 7, 2002 | 02:15 PM
Arntzman's Avatar
Guys,
What are the differences between a 305 crank and a 350 crank? I've heard that the journals and stroke are the same but balancing may be different. Is anyone running a 305 crank in a 350 and have you had any problems?
Thanks,
Dave
Old Mar 7, 2002 | 03:17 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
They are both identical, except after balancing. The 350 crank is balanced with less material removal, plus the counter weights grooves are offset (can't lay a straight edge flat on them). The 305 crank is balanced with more material removal, plus the counter weights grooves are not offset (you can lay a straight edge flat on them). Other than that, they share the same part number (prior to balancing).
Old Mar 8, 2002 | 01:26 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
MrZ,
Wow, is that ever a gorgeous Z28!!!
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
