Open rubber line from EVAP canister
Old Mar 10, 2002 | 08:53 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have a line from my EVAP canister that 'Ts' to a line going to the back of the car and one under the passanger side of the air dam going into nothing. Should this line go to anything or is this how it should be?
Old Mar 11, 2002 | 12:39 AM
darbleinad's Avatar
Car: 84 Trans Am
i doubt the open line is correct. on my 305 4bbl 84 Trans Am, which is a Canadian, the canester had a line running to the back of the car to the fuel tank and at least one line running into the carb and one that plumbed into the pcv value line coming from the front of the drivers side valve cover and running into the base of the carb.....there may have been a couple of lines going directly to the carb...i cant remember...but there was at least one. i took mine out about a year ago...so i am not sure the exact line routing.....but the point is that likely that open line is supposed hook up to something...likely somewhere on the motor (but i dont know where cause you car will be fuel injected and i dont know too much about fuel injection). if you look under the hood (if it is stiill there or not covered in oil), in front of the rad support, not far from the hood latch there is normally a sticker that shows the emissions hose routing...check there....that might help determine where that open line belongs.
i hope this is somewhat helpful
Old Mar 11, 2002 | 09:54 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
mine had a t but nothing on it, just line to tank............so i plugged it
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
