Roller cam assembly lubing...
Old Mar 11, 2002 | 02:24 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Before I get everything back together I just want to make sure that I lubed the thing right. I drenched everything (lobes, journals, dist gear) in regular 5w-30 an stuck it in. I have the roller lifters in a tub of oil right now along with the roller rockers.
I heard to use whatever oil I run in it normally. Just double checking...don't wanna screw anything up.
thanks fellas...
Old Mar 11, 2002 | 04:01 AM
ede's Avatar
ede
i'd prime the oiling system before i put the distributor in, and i like 30w oil for break in, but anything should work you normally run.
Old Mar 11, 2002 | 06:30 AM
Nitroburn's Avatar
I used the bearing assembly lube (that came with the main/rod bearings) on the cam bearing journals and motor oil on the roller cam lobes. I also use the assembly lube on the side of the pistons and rings and a thin coat on the cyl. walls before inserting the pistons.
Regular motor oil on everything else.
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
