Please help, need to get car started.
Old Mar 12, 2002 | 07:20 PM
Hulk0202's Avatar
OK friends car crappy 4cyl with a 2bl carb. It sat for a year, was fine when parked. I changed plugs, wires, rotor, cap, fuel filter, pump. Car will start but dies at idle. Can keep it going playing with the throttle. If you give it steady gas, it seems to cycle: runs, revs up, starts to die, repeat. I noticed that one barrel of the carb wasnt spraying fuel Should it always be spraying or just under heavy acceleration? Please, ANY suggestions are greatly appreciated.
Old Mar 12, 2002 | 08:36 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
i dont think its supposed to be spraying fuel.. just had same problem.......did a carb rebuild..cleaned it all up....all is fine..
not sure though
cant go wrong with a carb rebuild
Old Mar 13, 2002 | 05:20 AM
Hulk0202's Avatar
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
