Installing cam "straight up" or "4 degrees adv"
Old Mar 16, 2002 | 04:45 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I understand what this is referring to, but what is the result? What is the benefit over one way to another?
Old Mar 16, 2002 | 09:05 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
it really depends on your combination but
in most cases, straightup is best. The real time to change it is after you have driven it some and determin you need to move the powerband up or down.
Old Mar 16, 2002 | 11:57 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if I have this right when you advance the cam you are going to give more higher rpm power
where if you retard it you are going to have a loss of high rpm power though when you retard it you get a flatter powerband I think
I could easily be wrong though
Old Mar 16, 2002 | 12:00 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
That's backward RX. It's advance for low-end and retard for high end.
Old Mar 16, 2002 | 02:28 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Hehehe, how would YOU know, you don't even have a cam! Just messin with ya
If you advance it you make the power happen SOONER=low end. If you retard it you make the power happen later=top end.
I just finished my cam swap where I retarded the cam 2* in order to push the power up some. With a DTD'd 400 ft-lbs @ 2000 rpm I think I can spare a little low end
Old Mar 16, 2002 | 09:52 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just don't tell the guy at NAPA that
I figured it was one way or the other just couldn't remember for sure
and if you retard it doesn't it also make a flatter torque curve rather then a peaky one like it would with the cam advanced
Old Mar 16, 2002 | 11:15 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Actually, according to "Desktop Dyno" Advancing a somwhat radical cam brings more torqure in, Sooner, and lowers your peak horsepower. the torque curve seems to flatten out when advanced, and starts higher and sooner.
Retarding the cam in desktop dyno brings your peak horsepower UP, and makes it occur LATER in the RPM range, and retarding also makes your torque lower, and it waits longer before getting flattened out...
I prefer advanced 4-6* for the street, retarded 2-3* for Racing.
If you have a high stall converter, technically its better to have it retarded because you see those higher RPMS constantly...
Straight up isnt always stright up though, nearly ALL cam manufacturers include a ground in advance. simply adding a little shiny piece of metal to the timing chain takes care of that however...
Old Mar 17, 2002 | 12:14 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
When I installed my Xtreme cam it already came 4 degrees advanced.
BlueIroc-Z
Jun 9, 2019 03:22 AM
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
