Will my V6 rear end hold up to V8 power?
Old Mar 16, 2002 | 10:59 AM
Xenodrgn's Avatar
Just curious... if I were to buy a V8 parts car and swap the drivetrain into my frame, will I be able to use my 3.42's? Or will I be cursed into using the most likly stock 2.73 or 2.77's...?
Old Mar 16, 2002 | 11:04 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The 10 bolts are identical. I got the 3.42's from an 88 v6 5 speed, other than the powertrax the components came from a V6 car.
Old Mar 16, 2002 | 11:06 AM
Xenodrgn's Avatar
Sweet. Thanks for the prompt reply SSC!
Old Mar 16, 2002 | 11:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Other than gear ratio options, there is nothing different from a V6 to a V8 diff. The best diff to find is from a 90-92 car since it will have the larger 28 spline axles. Older diffs can be upgraded to 28 spline axles but the carrier needs to be swapped also.
cheesehomer
Dec 31, 2015 08:48 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
