What transmissions can I put behind my 6?
Old Mar 16, 2002 | 11:25 AM
Xenodrgn's Avatar
700R4's are expensive as hell, lets face it... and the 1-2 drop is a joke. Since I need a new transmission anyway, are there any other ones that will bolt up behind my 6? I know about the 200C, but there must be a reason why that was done away with. Will a TH350 bolt up? Or can redrill it to bolt up? They're pretty cheap to both buy and rebuild, and they're more of a spirited tranny anyway... what do you guys think?
Old Mar 17, 2002 | 02:29 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
with the small bolt pattern you aren't left with much. if you don't want to stay with the 700R4, i'd say look for a 5 speed. when i had my 2.8 i used a 700R4 i built and used a 2800 stall converter it worked great. just changing the stall converter alone picked up .5 seconds. putting together a 3.4 with the mpi from a 91 firebird now for my s10 except with 3.23 this time (last time was 4.10).
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
