where is the electric cooling fan relay located?
Old Mar 17, 2002 | 09:42 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i need to find the relay so i can hook up a line to the green/white wire so i can make a manual override for my fan
Old Mar 17, 2002 | 10:35 AM
Vader's Avatar
Matt,
The fan relay should be near the right front corner of the engine compartment, near or mounted to the radiator support.
Old Mar 17, 2002 | 12:22 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
ok
thanks
Old Mar 19, 2002 | 12:27 PM
War_Eagle's Avatar
I like the idea of a manual overide switch for the cooling fan, to be able to turn the switch on/off from inside would be great. Has anyone done this? Step by step, how would you go about doing it correctly?
Old Mar 19, 2002 | 06:25 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
this is what a guy told me to do
Locate the existing fan relay. It has the following wires: Orange, black/red, tan/white and green/white. Splice (do not cut) into the green/white wire with a new section of 18-gauge wire. In other words, "tee" into the existing green/white wire. Connect the new wire to a toggle switch. Ground the other switch connector. The fan will now turn on with the switch as long as the ignition switch is on. A lighted switch can be used, but it complicates the wiring slightly.
the only thing is that im still trying to find the green/white wire
good luck
Old Mar 19, 2002 | 08:46 PM
Vader's Avatar
Matt,
The other place you could tap the green/white wire is near the temperature switch in the RH cylinder head - same wire.
Old Mar 19, 2002 | 09:19 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright
thanks!!
Old Mar 20, 2002 | 03:08 PM
War_Eagle's Avatar
Thanks for the help...... I'm getting started on the switch right now.......
RazorN8
Jan 7, 2022 11:44 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
