What kind of roller rockers have you run under centerbolt valve covers?
Old Mar 18, 2002 | 04:34 PM
Derrick's Avatar
I see that Comp Cams offers a set for $200. Part #1418-16. This is the cheapest I have seen. Has anyone used these? They don't say anything about being self-aligning or non-self-aligning. Does it matter? Thanks for any help.
Old Mar 18, 2002 | 04:40 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I am running Proform Aluminum roller rockers. I have heard some people on here don't advise using them. I personally have had no problems, but I only have about 600 miles on them. I originally used the Proform roller tipped rockers and broke 4 of those. After I called them, they replaced the whole set with the aluminum ones.
Old Mar 18, 2002 | 05:07 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
crane gold race roller rockers, 1.5 ratio...think i paid 300...no problems
Old Mar 18, 2002 | 05:44 PM
ede's Avatar
ede
i'm running comp 1318s, had to make a set of valve covers
Old Mar 18, 2002 | 05:54 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I hear the Comp 1318's are real good. They are steel and are supposed to be lighter than the aluminum kind.
Personally I have Crane Gold's because I didn't want to mess around with chopping the "scaffolds" out the valve covers. I also had a hard time spending $300 on rockers I really didn't NEED. It was just a "while I'm in there" kinda thing. They fit fine with no modifications to the valve covers. Test fitting a modified valve cover in my van would be worse than watching 4 hours of Lawrence Welk re-runs.
I think the Comp 1318's go for about $320 (?). Not positive tho.
EDIT: I got my rockers thru AutoZone for $270...$30 less than Jegs and Summit and I didn't have to pay shipping
Old Mar 18, 2002 | 08:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
a set of el cheepo proforms
but.. they will get changed for a set of comp pro magnums soon. I found them for 230-240 bucks depending on studs and ratios.
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
