roller lifters and problem w/afr head
Old Mar 18, 2002 | 08:41 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
how many rpm's should a stock replacement lifter (roller) can
handle? Also like to know if anybody had any problems w/ AFR
valve springs and valves?
Its taken 3 bent valves(same cylinder), 2 chips, scan tool,&
lots of $ in machine work and gaskets to find my problem.
I am so pissed off because I built my engine 1 year ago and I still don't have it right. I had paid good $ for these pieces of s**ts
($1700 to be exact) and I really want to shove it up AFR's ***!lala:
My NEW machine shoprec. all new valves and springs because
the valves were pitted at the tips and the springs were below
spec. only 3000miles on engine.
Knock sensor would go crazy at 2600 rpm, but I managed to pull of 275hp / 382 tq. with 8deg knock retard
355, 10.86-1, splayed 4-bolt, zz4 forged crank, Eagle I-beam rods,speed-pro forged pistons,
afr 190cc heads, comp cams 1.52 rollers,
zz-9 cam, big mouth intake, large tube runners level 5 chip tpis
52mm plate
edelbrock TES headers, 3" exaust
84z96L31vortec
Aug 20, 2017 12:16 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
anesthes
Aug 8, 2015 09:37 PM
