i think i have a timing problem....please help
Old Mar 18, 2002 | 09:12 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok when you set timing do you need to unplug something so the distributor is free from the computer....i heard this somewhere....cuz i just tried messing with my timing the other day and now my car is slow as sin.....its got torque....kicks on everyshift...but it WONT go past 4,000 RPM's it just barely gets there and there is NO pull what so ever......hmm....maybe my cat is clogged
i'll post this on the exhaust board too to find out
but any info would help.....im goin to the strip this weekend and i would like my car to run good!!
thanks
Old Mar 19, 2002 | 10:01 AM
Vader's Avatar
Matt,
Your '84 should have an EST control, but according to my diagrams there may not be a bypass connector. In your case, you may have to insert a jumper between the 'A' and 'B' terminals of the ALDL to bypass the EST to set the base timing. Refer to the VECI label under the hood for certainty.
I'd suggest the stock base timing setting or possibly only 1-2° extra advance to start with if you are running better grade fuels.
Old Mar 19, 2002 | 04:06 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
ok thanks.....i have no idea what you just meant by all that but what i got out of that was that i do need to mess with my timing some more....thanks
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
