Clueless... What to try next?
Old Mar 19, 2002 | 12:16 AM
BigRed42's Avatar
My car has been running horrible lately. 9-10 mpg! Big time loss of power (as if there was already much to lose) We run it on the computer, everything is fine untill it gets up to temp. Then the o2 cross count sticks at 000 and it runs horribly rich. So far we have put in a new 02 sensor, MAP sensor, and coolant temp sensor. TPS sensor is fine. At idle, it'll run fine, then begin to die, and than catch itself and run fine again. All fuel pressure is fine... same with compression! Any ideas on what to check next? Thanx!
Old Mar 19, 2002 | 01:32 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
How about your injectors? Mybe some of them are leaking heavily.
Old Mar 19, 2002 | 04:33 AM
ede's Avatar
ede
check for a clogged cat
Old Mar 19, 2002 | 10:30 AM
Vader's Avatar
A clogged air filter or restricted intake?
Old Mar 19, 2002 | 01:37 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Check your snorkel to make sure some f*ckstick hasn't let the windshield washer fluid cap to get sucked in.. that was restricting lots of power for me and causing my car to disel, hehe....
Old Mar 19, 2002 | 01:41 PM
jfox55's Avatar
check the vacuum lines going to the map sensor at the scensor and on the engine. mine rotted in half, made the gas mileage terrible, ran really rich, not much power smoked balck
Old Mar 19, 2002 | 09:15 PM
BigRed42's Avatar
thanx guys... i'll update as soon i work on the car again!
nelapse
Dec 26, 2006 01:43 AM
hate101
Oct 25, 2006 06:24 PM
drews91maro
Dec 15, 2005 05:43 PM
JCherwien
Mar 1, 2004 09:56 AM
rockfourone
May 16, 2003 09:12 PM
