oil leak
Old Mar 19, 2002 | 02:55 PM
BamaZ28's Avatar
oil leak
i got a couple of leaks coming out of my car... the first is from the front of the engine... can oil leak out from around the timing chain cover??? the second is the front pump on my tranny... how hard is it to replace the front pump????
Thanks,
Josh
Old Mar 19, 2002 | 05:32 PM
Stroked-Z's Avatar
Yes oil can leak from around the timing chain cover. It usually leaks at the gasket though right at the bottom of the timing chain cover that mates with the oil pan. To fix this PROPERLY, you have to loosen the pan bolts, drop it down about 3/4" at the front and re-install the timing chain cover with new gaskets. Then bolt the pan back up.
The front pump on the tranny is very difficult. The tranny must be removed & i believe you need a special puller to yank that pump out.
Good Luck.
Old Mar 20, 2002 | 07:28 AM
BamaZ28's Avatar
thanks... this is going to be my project to do this weekend.
Josh
Old Mar 20, 2002 | 10:44 PM
85 Berl's Avatar
Are you sure the tranny leak isn't the pump seal? That isn't that hard to fix, just time-consuming.
Old Mar 21, 2002 | 12:06 PM
BamaZ28's Avatar
i'm not real sure... the tranny is starting to lay down anyways so I'm thinking I will just replace it...
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
