WTF? Where this water leak come from?...
Old Mar 20, 2002 | 09:04 PM
ChevyLuva3's Avatar
Today it was terrible weather, it was snowing, but it would melt when it hit the ground, so it was like white rain. Well I get into my car, look over at the passenger side floor... WTF!? A giant friggin puddle, just sitting there, and nothing dripping to make it wet. It just got wet some how, it was drenched, where the hell did this leak come from? What is it leaking underneath the carpet? I haven't had this leak before, crazy.
Any help would be greatly appreciated.
...BTW, the car I used to use, my dads 86 Grand Am, which I used while trying to find Camaro, is now totaled. I was driving down a road, around a turn, I see this car, and a guy waiving or something, so I goto move to the middle of the road to get out of way, then my car starts slipping and hydroplaning. I started fishtailing, I was trying to hold it as best I could... but then the rear end slipped around and BAM.. I nailed the front end into the tree, the car is totaled. I wasn't even close to speeding, the road was just on giant piece of ice.. black ice. Luckily those old 86 Pontiac seat belts held me in, even some of the plastic came off. I even got seatbelt bruises, luckily I was wearing seatbelt, I got bruised knee/shin, might have been worse... It was on Monday, it was snowing, sleeting, everything, the weather was bad for my Maro, so I took the ol trusty Grand Am, unfortunately I guess Allendale didnt salt . Thank G0D, I didn't take my Maro out, but I'd rather not have either car totaled. BTW, there was two cars I had to swerve around, they were on the sides of the road, they crashed before me! And that was technically my first car, I had fun in it, I loved it as much as my Maro. Thought I'd letchas know, lets all say a farewell to the 86 Grand Am...
Old Mar 21, 2002 | 07:06 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
sorry about your car man. about your leak though, it could be your heater core leaking antifreeze or like in my car, someone put a hole in the firewall to run wires and didn't plug it afterwards. also check your weatherstripping, it's notorious for leaks, especially t-tops
Old Mar 22, 2002 | 06:17 PM
ChevyLuva3's Avatar
BTT.. leak?
Old Aug 19, 2002 | 03:12 PM
FLYNLOW92rs's Avatar
Need to bring this back from the dead......
I have this same problem and culdn't find an answer......any ideas as you where this leak is comming from????
No heater core in my car.....a big puddle of water after i drive in the rain.....
I'm clueless help....
Old Aug 19, 2002 | 05:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
basically what ukrane said. Probably water leaking in through the weather stripping on the door, window, or t-tops or maybe a hole that has rusted through somewhere int eh car. Mine does this sometimes when its a real hard driving rain because the weahter stripping on the t-tops themselves that shrouhds the windows was cut off by the last owner.
Old Aug 19, 2002 | 06:35 PM
no t-tops
No leaking on the door....
Old Aug 19, 2002 | 06:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad to see it was an old post... if it was snowing in NJ in August and I missed it, I'd feel really left out!
Might be bad sealant at the base of the windsheild...
Old Aug 19, 2002 | 09:59 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I had a similar problem on my car, but it was on the drivers side. Water would come in under the carpet when it rained. It turned out to be a crack in some black sealant under the grill near the wipers. You know the black grill that goes along the car between the windshield and the edge of the hood? Remove the bolt it has holding it down in the middle, and gently lift one corner up. Look under there with a flashlight. I had some pretty big cracks down there, but I fixed it with some black silicon. The water would come into the car through there, and travel down along the firewall, under the carpet. That may or may not be the problem on your car, but go take a look.
Old Aug 20, 2002 | 03:01 AM
Enkil's Avatar
Just a shot in the dark here, but you say you don't have a heater core in your car, so I'm assuming you did an AC delete and went ahead and took the heater out too. When you did that, did you take out the ac box (don't know the name for it) that sits on the firewall in the engine bay on the passenger's side?
Old Aug 20, 2002 | 05:19 AM
ede's Avatar
ede
preasue test the cooling system to see if it leaks and sonic test the seals to see if they leak
Old Aug 20, 2002 | 12:13 PM
89Irocz23's Avatar
Why not just sitin the car and have someone spray water all over the window and other places see if its a leak from rain or something. If not try the cooling system.
Old Aug 20, 2002 | 12:40 PM
I'll test out all of your ideas probally tomorrow or tonight....
It's water not coolant and i don't run the AC in my car although it is there...
Old Mar 23, 2005 | 11:33 PM
cozhavok's Avatar
Car: 1985 Camaro Z28
Engine: LB9 V8
I had a wet passanger floor so I took out all my interior and put a garden hose on my roof and found out where it was coming from. There is a wiring harness behind the passanger kick panel. That is where I found my leak. Now I just have to figure out how to stop it. My car also smells like mildew so I have to figure out how to get rid of the smell too. Any Ideas let me know.
Old Mar 24, 2005 | 11:54 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
on the leak, get a tube of black RTV silicone & pull the rubber plug out, do not cut the rubber plug off the harness, if you can, slide it down the harness some & put some silicone on the harness & then slide the plug back into place. next put some silicone on the outside of the rubber plug into the groove where it mounts in the sheet metal & put the plug back in & let it dry.
on the mildew, you will need to replace the padding under the carpet. replace any of the padding that may have gotten wet. water will wick through the padding & can be wet on the drivers' side even though the leak was on the passenger side. if you leave in any of it that has been wet, the smell will come back. the padding isn't too expensive so you could replace all of it.
when you have the carpet out, get a can of Lysol disinfectant spray & spray down the floor boards & the back side of the carpet. you could wash the carpet while it is out also, if you do wash it, do both sides, the bottom first & then the top. a stiff bristle push broom & laundry detergent works for me. be sure you get all of the detergent rinsed out.
DO NOT use anything that has bleach in it! then hang it up to dry in the sun for a few days. before you put the carpet back in after washing, spray the bottom side down with some Lysol.
of course before you replace the padding & clean the carpet, make certain that all of the water leaks have been fixed.
Old Mar 25, 2005 | 02:59 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
wow this is an old post and I remember the person who started it
we got into a HUGE debate
thanx for the memories man
Old Mar 25, 2005 | 02:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
arnt you the guy with the custom lexan windshield? think I looked at your cardomain site a long time ago.. anyhoo maybe it isnt sealed well enough? But like others said, have one person sit inside for leaks while someone else goes along the normal leak points with a garden hose, thats what we do at the dealership I work at, maybe not too scientific but it works.
Old Mar 26, 2005 | 08:50 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the dealer has a spray you can buy, oderless (really is) and this stuff really works! I thought sure but, gave it a shot and did it just as the directions say and wow it works
Old Mar 26, 2005 | 04:46 PM
cozhavok's Avatar
Engine: LB9 V8
What is the stuff called an do you have a part number?
Old Mar 26, 2005 | 05:48 PM
Engine: ls1, LB9
I don't know but, I can find out. 90% of the dealers will have it. they should know what you want (they use it in the vents and evap core for a musty smell removal)
Old Jul 21, 2005 | 11:03 AM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
Hurray for search!
I guess that mystery leak is a dang wiring harness? Gay...
Old Jul 21, 2005 | 11:46 AM
cozhavok's Avatar
Engine: LB9 V8
Well i put all new weather stripping all around the t-tops, doors and hatch and had holes welded on roofline where previous owner ran screws through the roof trying to hold up the plastic strip above the back seats and I had the wiring harness sealed up on the passengerside panel and NO MORE LEAKS!!! YAHOOOOOOO!
Old Jul 22, 2005 | 02:25 AM
DENN_SHAH's Avatar
Hurray for search!
who knows, ChevyLuva3 never posted back what it was he found.
i have seen plenty of water leaks caused by a wiring harness, some caused by the throttle cable, others caused by the speedo cable, then there have been a few caused by the hood release cable.
i have even seen a coolant leak inside the car that was caused by the computer system.
glad you got it done cozhavok
did you use silicone to seal it up?
Old Jul 22, 2005 | 04:37 PM
Sorry for my ignorance but...
Was my first impression.
Anyways, I did some brief looking around and I have some kind of cancerous rust bursting crack near the passenger rear of the front fender on the fire wall. I think I am going to put some sealant on that thing.
Old Jul 22, 2005 | 06:49 PM
DENN_SHAH's Avatar
yep, the computer system was the cause of the coolant leak in the passenger side floor board.
as you probably don't know, GM used some poorly designed coolant sensors & connectors in the early days, the sensor would start to leak & the coolant would wick up into the wiring harness. the insulation on the wires would break down & short together & kick a code. but on this car that didn't happen, the insulation stayed intact. the coolant flowed up through the wires into the ECM, then puddled up under the carpet. it was a easy fix with some new padding, cleaned carpet, a new sensor, connector, ECM & replacing the CTS wires.
i think some silicone sealant will fix that rust right up
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:37 AM
