Help, engine shaking?
Old Mar 22, 2002 | 07:24 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
OK, got a vibration at 1000 - 1300, goes away until 2000-2500, causes dash to shake up and down. Does it in neutral, in the driveway, and on the road when moving, so it is not driveline.
Looked at torqu converter, it looks like it is true.
When the engine shakes, it looks like the harmonic dampener is out of round?
The dampener was new with the engine. I have a new fluidamper I am about to try.
Any other suggestions
Cheers
Richard
Old Mar 22, 2002 | 09:39 AM
Spyder's Avatar
I would check the rubber on the motor mounts and make sure they are still good. Also your flywheel could have kicked a weight
Old Mar 22, 2002 | 09:42 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Thanks for the response, unfortunately, new mounts, and new flexplate when engine installed. ( By dealer ).
Cheers
Richard
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
