oil leak
Old Mar 22, 2002 | 07:31 PM
primer84z's Avatar
oil leak
i have a 84 z28 with a 305 that was built this summer. there is a oil 'drip' coming from the bottom of the transmission belhousing. its a 5 speed manual if that matters, the oil just drips off of it real slow maybe a puddle the size of a quarter will be there after one night of sitting. any guesses as to what could be leaking?
Old Mar 22, 2002 | 08:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: oil leak
If it's engine oil, it could be the valve covers, the intake manifold, oil pan or the rear main seal.
Old Mar 22, 2002 | 08:46 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Newly rebuilt motor? Hmm. I'd have to say the oill pressure sending unit. Round cylinder about 1.5 inces long with one tan wire and connector plugged into it. Located on drivers side near the firewall next to distributor. Check it out. Its only about 5.00 to replace and will save you alot of money from adding oil all the time.
Old Mar 22, 2002 | 10:53 PM
topdown's Avatar
Check and tighten oil pan and valve cover bolts. They may need a 1/2 turn or so after a rebuild(especially if they weren't torqued right to begin with) Be careful not to over tighten!
Old Mar 23, 2002 | 01:04 AM
TBI305Camaro's Avatar
sounds like what mines doing...check the oil pressure sending unit and the intake...im almost positive its my intake leaking right now...i want to change the intake so im kinda holding off and waiting till i swap intakes or swap to a carb and new intake
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
