TPS Problems?
Old Mar 23, 2002 | 05:18 AM
larsulrik1's Avatar
TPS Problems?
A few months ago my 305tbi would intermittently try to stall out at idle every few seconds. A few days ago when I tried to start it, it just cranked and cranked without turning over. It finally turned over after a couple of minutes but idled around 1500 in P and 1000 in D. It set the TPS #21 code right away and it continued to take it's time starting. Today I pulled the connector and it started right up everytime but still idled high. Do the first and last problems sound related and does it just sound like a bad sensor? Thanks.
Old Mar 23, 2002 | 12:29 PM
CEDOE's Avatar
lets see
did you check your TPS voltage (should be at .54 idle and over 4 volts WOT) ?
Old Mar 25, 2002 | 09:48 AM
Vader's Avatar
Have you cleaned the throttle body / IAC lately?
92camaroJoe
Jul 29, 2023 07:57 PM
GTAman
Sep 21, 2015 09:57 AM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
