Corvette heads What about EGR ??
Old Mar 23, 2002 | 06:37 AM
89blackbird's Avatar
Hey guys I know some of you have corvette heads on your cars. What did you do about your EGR?? There is no cross over with these heads. Thanks
Old Mar 23, 2002 | 08:54 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I don't run vette L98 heads, but to run those heads and keep the EGR you will need to plumb a tube off the headers or manifold to use with a remote mounted EGR valve..... You will need to plumb the EGR feed line into the intake as well.
I would really guess that most guys just run without EGR and disable the EGR diagnostics in the PROM.
Hope that helps.
Old Mar 23, 2002 | 11:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TPI base for the Vette aluminum head version of the L98 has provisions for the external exhaust tube with the EGR valve located in the same place as the 3rd Gen version of the L98.
You do need to run that external tube from exhaust manifold to base, though.
Old Mar 24, 2002 | 01:21 AM
Blackened's Avatar
Who cares about EGR ?...
Old Mar 24, 2002 | 02:51 AM
Matt87GTA's Avatar
Well.... from the looks of it, the person who started this thread!??
Old Mar 24, 2002 | 09:55 AM
Guest
Guest
Posts: n/a
I replied to your other post, never connected mine.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
