Engine startup problems
Old Mar 23, 2002 | 06:47 PM
crazeinc's Avatar
Headers turning bright red, not idling.
It's been established my vac. advance distributor even while unplugged still advances is a problem, but I don't think it's causing these. I've tried 2 different carbs and 110 octane but nothing seems to do the trick. I had similar problems on the last engine and they just seemed to go away after the cam was broken-in but it was also overheating last time and it isn't now. My friend says the cam's a tooth off, I say maybe intake leak.
Any ideas? Here's the motor:
355, 256/263@.050 solid cam, victor jr. intake., holley 750, sportsman 2's.
Old Mar 23, 2002 | 06:57 PM
ede's Avatar
ede
check your timing, make sure est is disabled when you set it and it advances or retards correctly, you have retard box on it? if so check it out
Old Mar 23, 2002 | 07:20 PM
crazeinc's Avatar
est is disabled? The distributor isn't computer-controlled if that's what you mean.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
