Quick q; please help--I can't remember where the hole is for the engine dipstick?
Old Mar 24, 2002 | 12:03 AM
cort351w's Avatar
I have a 91 Formula LB9.
I need to install my new dipstick (Lokar flexible dipstick) and I don't remember where the old one was.
Is it the hole almost directly below the bolt that holds the AIR-tube-for-the-cat to the cylinder head? The hole I'm thinking of seems to be in a corner (i.e. drill the 90* bend in a piece of angle iron at a 45* angle). I'm not sure because I've never been able to see the hole. I'm sorry I can't be more specific.
Also, the dipstick mounts using a header bolt, correct?
I would like to go put the dipstick in--please help.
Edit: Topic was originally a question and I forgot to delete the question mark. It just looked weird to me when I saw the post listed so I'm explaining it.
Old Mar 24, 2002 | 01:21 AM
Blackened's Avatar
You gotta be kidding !!!
Old Mar 24, 2002 | 10:23 AM
FstBrd6point3's Avatar
it is on the side of the block right near the knock sensor. . at least that is where it was on my L98. . . it is on the flat surface of the block right above the oil pan
Old Mar 24, 2002 | 12:43 PM
cort351w's Avatar
Thanks. I really couldn't remember where it came out of. This is the first sbc I've had and the dipstick was only on for the first couple times I was working on the car. It's been four months since then so maybe you can see why I wasn't sure. Now that I think about it, my guess WAS pretty bad. What can I say? I will not post on any dipstick related topics until I master this dipstick .
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
